Ga door naar hoofdinhoud
Comment forcer le redémarrage de l'iPhone 11 Pro Max
Wat je nodig hebt
  1. Comment forcer le redémarrage de l'iPhone 11 Pro Max, Comment forcer le redémarrage de l'iPhone 11 Pro Max: stap 1, afbeelding 1 van 1
    • Appuyez brièvement sur le bouton d’augmentation du volume (1)
    • Appuyez ensuite brièvement sur le bouton de diminution du volume (2)
    • Il faut vraiment appuyer très brièvement
    Thank you so much! This truly worked! We didn’t know what to do with my phone when it froze this was a life saver more importantly because customer service closed earlier! Thanks again
    Marco Jackson - Antwoord
    So my question is do you do this simultaneously?? Or one at a time?
    jameciahardy - Antwoord
    this worked, but had to do it a few times, phew ! Thanks
    lise bourgeois - Antwoord
    okay i see the coment everyone says it working but i pressed them down and nothing showed up .please respond
    Ernest Toth 11 Clifton - Antwoord
    i’ve done this many times nothing happens need phone traveling in the morning
    kjmil54 - Antwoord
  2. Comment forcer le redémarrage de l'iPhone 11 Pro Max: stap 2, afbeelding 1 van 1
    • Pour finir, maintenez le bouton latéral enfoncé jusqu’à ce que le logo Apple apparaisse (3)
    Und wenn das iPhone auf Tastendruck nicht reagiert?
    Peter Hellweg - Antwoord
    Thanks. Finally I got my frozen phone to shut down. Instructions on another site didn’t say to press and release the volume up then down buttons quickly, then the sleep/awake button. That seemed to make all the difference.
    Joe P - Antwoord
Eindstreep
39 andere personen hebben deze handleiding voltooid.
15 opmerkingen
Klappt - vielen Dank:-)))
Marlene Dietrich - Antwoord
This Worked! Thank You so much!
Ashonda Warner - Antwoord
❤️Many thanks
angelamacuser - Antwoord
Still not working
stephen fleming - Antwoord
still didnt work
steve doddridge - Antwoord
same im trying a million times and nothing
still not working
Veronica Pellino - Antwoord
It worked perfectly!
Dawn McVey - Antwoord
still didnt work
Gina DeMeo - Antwoord
help me please
Thank you! I have never had an app freeze like that.
Wanda Kalencki - Antwoord
der Tipp, nur ganz kurz zu drücken, war ausschlaggebend. Vielen Dank, Iphone wieder okay!
Catrin Geerdes - Antwoord
thank you it help me
Mabrouk Zayed - Antwoord
Thank you for helping me.
Alireza Ghodousi - Antwoord
Worked. Thanks alot
Ummer Kader - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 20
Afgelopen 7 dagen: 131
Afgelopen 30 dagen: 518
Altijd: 200,873
