Inleiding
This guide shows how to remove the antenna, volume and channel dials, and the exterior case.
Onderdelen
Geen onderdelen nodig.
  1. Look for the release button on the back of the radio. Press the button and pull down on the battery at the same time. The battery will come free. Press the button and pull down on the battery at the same time. The battery will come free.
    • Look for the release button on the back of the radio.
    • Press the button and pull down on the battery at the same time. The battery will come free.
  2. Twist the antenna counter-clockwise to unscrew it from the antenna jack.
    • Twist the antenna counter-clockwise to unscrew it from the antenna jack.
  3. Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  4. Pull up on the dials to remove them from the underlying pegs.
    • Pull up on the dials to remove them from the underlying pegs.
  5. Using a T15 Torx screwdriver, unscrew the two screws. Using a plastic opening tool, pry the internal case from the external case. Using a plastic opening tool, pry the internal case from the external case.
    • Using a T15 Torx screwdriver, unscrew the two screws.
    • Using a plastic opening tool, pry the internal case from the external case.
Conclusie
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 0
Altijd: 84
