Inleiding
Have you troubleshooted everything else and nothing is working to fix the device? Replacing the main power board might be your last resort.
Wat je nodig hebt
Carefully turn the lantern upside down.
Remove the three 1.2 mm Phillips #0 screws from the base of the lantern.
Remove the single 1.2 mm Phillips #1 screw on the bottom of the lantern.
Remove the plastic barrier.
Bijna klaar!
Conclusie
