Ga door naar hoofdinhoud
Inleiding
The purpose of this guide is to give step-by-step instruction on how to replace the motherboard on a ColecoVision.
Onderdelen
Geen onderdelen opgegeven.
  1. Start by laying the console face down.
    • Start by laying the console face down.
    • Remove the eight 15mm Phillips #1 screws from the bottom of the device.
  2. Flip the console back over. Lift the front panel off. I would reccomended using a metal spudger along the rim of the top to safely remove it and set it aside.
    • Flip the console back over.
    • Lift the front panel off. I would reccomended using a metal spudger along the rim of the top to safely remove it and set it aside.
  3. Remove the two 15mm Phillips #1 screws holding the casing in place. Carefully lift the casing from the motherboard.
    • Remove the two 15mm Phillips #1 screws holding the casing in place.
    • Carefully lift the casing from the motherboard.
  4. Remove the center Phillips #1 screw near the cartridge slot.
    • Remove the center Phillips #1 screw near the cartridge slot.
    • Remove the second Phillips #1 screw near the RAM chips.
    • Carefully lift and remove the motherboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Krystalina
121 Reputatie
1 Handleiding geschreven
UW Tacoma, Team S1-G2, Rose Fall 2018 Lid van UW Tacoma, Team S1-G2, Rose Fall 2018
UWT-ROSE-F18S1G2
4 Leden
12 handleidingen geschreven
0 Opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 19
Altijd: 834
