Wat je nodig hebt
Use a spudger to remove the four rubber screw covers from the four back corners of the tablet.
Using the PH00 screwdriver unscrew and rotate the plastic tabs that are holding the screen in place.
Gently pull on the black tab connecting the ribbon cable to the back of the tablet.
Remove ribbon cable from port to free the digitizer.
Één andere persoon heeft deze handleiding voltooid.
