Ga door naar hoofdinhoud
Coby Kyros MID7125 Speaker Replacement
Wat je nodig hebt
  1. Coby Kyros MID7125 Speaker Replacement, Speaker: stap 1, afbeelding 1 van 1
    • Use opening too to make small opening in the side of the device.
    • Use plastic opening tool to pry the rest of the panel off.
  2. Coby Kyros MID7125 Speaker Replacement: stap 2, afbeelding 1 van 1
    • Once inside the device, locate the speakers on the inside of the back panel.
  3. Coby Kyros MID7125 Speaker Replacement: stap 3, afbeelding 1 van 1
    • Use spudger to pry one speaker up off of the back panel.
  4. Coby Kyros MID7125 Speaker Replacement: stap 4, afbeelding 1 van 1
    • Desolder the soldering points that connect the speaker to the motherboard.
  5. Coby Kyros MID7125 Speaker Replacement: stap 5, afbeelding 1 van 1
    • Use a soldering iron to solder the wires of the new speaker to the motherboard.
    • Make sure, when soldering, to connect the red wire to the red and the black wire to the black.
  6. Coby Kyros MID7125 Speaker Replacement: stap 6, afbeelding 1 van 1
    • Click the new speaker into the spot where you removed the old speaker.
    • Follow steps 2-6 for the other speaker. Snap in back panel to put device back together.
Conclusie
Nicole Connelly
1 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 5-2, Martin Fall 2016 Lid van UMass Dartmouth, Team 5-2, Martin Fall 2016
UMASSD-MARTIN-F16S5G2
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 135
