Ga door naar hoofdinhoud
Coby DVD209 The bottom portion of the DVD player Replacement
Wat je nodig hebt
  1. Coby DVD209 The bottom portion of the DVD player Replacement, The bottom portion of the DVD player: stap 1, afbeelding 1 van 3 Coby DVD209 The bottom portion of the DVD player Replacement, The bottom portion of the DVD player: stap 1, afbeelding 2 van 3 Coby DVD209 The bottom portion of the DVD player Replacement, The bottom portion of the DVD player: stap 1, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Press the eject button to view the laser inside.
    • Using the blue plastic tool and the tweezers, remove the ribbon cable.
  2. Coby DVD209 The bottom portion of the DVD player Replacement: stap 2, afbeelding 1 van 3 Coby DVD209 The bottom portion of the DVD player Replacement: stap 2, afbeelding 2 van 3 Coby DVD209 The bottom portion of the DVD player Replacement: stap 2, afbeelding 3 van 3
    • Remove the six 1cm screws on the bottom of the device with the Phillips #1 screwdriver.
    • Do not lift the top of the DVD player too quickly because there are wires attached on the inside.
    • Pry the top of the device open from the right side where the buttons are located.
  3. Coby DVD209 The bottom portion of the DVD player Replacement: stap 3, afbeelding 1 van 3 Coby DVD209 The bottom portion of the DVD player Replacement: stap 3, afbeelding 2 van 3 Coby DVD209 The bottom portion of the DVD player Replacement: stap 3, afbeelding 3 van 3
    • When pulling the ribbon cables out, make sure not to pull by the wires, as this can cause damage to them.
    • Pinch the plastic adapter with two fingers to remove the wires circled in red from the circuit board.
Conclusie
Kyle VanAllen
70 Reputatie
2 handleidingen geschreven
Cal Poly, Team 10-36, Amido Winter 2012 Lid van Cal Poly, Team 10-36, Amido Winter 2012
CPSU-AMIDO-W12S10G36
4 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 16
Altijd: 327
