Ga door naar hoofdinhoud
Coby DVD209 4-Pin Ribbon Cable Replacement
Wat je nodig hebt
  1. Coby DVD209 4-Pin Ribbon Cable Replacement, The bottom portion of the DVD player: stap 1, afbeelding 1 van 3 Coby DVD209 4-Pin Ribbon Cable Replacement, The bottom portion of the DVD player: stap 1, afbeelding 2 van 3 Coby DVD209 4-Pin Ribbon Cable Replacement, The bottom portion of the DVD player: stap 1, afbeelding 3 van 3
    • Press the eject button to view the laser inside.
    • Using the blue plastic tool and the tweezers, remove the ribbon cable.
  2. Coby DVD209 4-Pin Ribbon Cable Replacement: stap 2, afbeelding 1 van 3 Coby DVD209 4-Pin Ribbon Cable Replacement: stap 2, afbeelding 2 van 3 Coby DVD209 4-Pin Ribbon Cable Replacement: stap 2, afbeelding 3 van 3
    • Remove the six 1cm screws on the bottom of the device with the Phillips #1 screwdriver.
    • Do not lift the top of the DVD player too quickly because there are wires attached on the inside.
    • Pry the top of the device open from the right side where the buttons are located.
  3. Coby DVD209 4-Pin Ribbon Cable Replacement: stap 3, afbeelding 1 van 3 Coby DVD209 4-Pin Ribbon Cable Replacement: stap 3, afbeelding 2 van 3 Coby DVD209 4-Pin Ribbon Cable Replacement: stap 3, afbeelding 3 van 3
    • When pulling the ribbon cables out, make sure not to pull by the wires, as this can cause damage to them.
    • Pinch the plastic adapter with two fingers to remove the wires circled in red from the circuit board.
  4. Coby DVD209 4-Pin Ribbon Cable Replacement, 4-Pin Ribbon Cable: stap 4, afbeelding 1 van 3 Coby DVD209 4-Pin Ribbon Cable Replacement, 4-Pin Ribbon Cable: stap 4, afbeelding 2 van 3 Coby DVD209 4-Pin Ribbon Cable Replacement, 4-Pin Ribbon Cable: stap 4, afbeelding 3 van 3
    • Position the DVD player so that the power and AVI ports are facing you.
    • Pull the white cable with the blue adapters off of the circuit boards.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Yufay Chow
92 Reputatie
4 handleidingen geschreven
Cal Poly, Team 10-36, Amido Winter 2012 Lid van Cal Poly, Team 10-36, Amido Winter 2012
CPSU-AMIDO-W12S10G36
4 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 1,007
