Ga door naar hoofdinhoud
Coby DVD-R11000 I/O Ports Replacement
Wat je nodig hebt
  1. Coby DVD-R11000 I/O Ports Replacement, Outer Casing: stap 1, afbeelding 1 van 3 Coby DVD-R11000 I/O Ports Replacement, Outer Casing: stap 1, afbeelding 2 van 3 Coby DVD-R11000 I/O Ports Replacement, Outer Casing: stap 1, afbeelding 3 van 3
    • Remove the four 1cm screws, two on each side, of the DVD player with the Phillips #1 screwdriver.
    • Remove the five 1cm screws on the back of the DVD player with the Phillips #1 screwdriver.
    • It is not required to remove the other seven screws in the middle between the I/O ports.
  2. Coby DVD-R11000 I/O Ports Replacement: stap 2, afbeelding 1 van 3 Coby DVD-R11000 I/O Ports Replacement: stap 2, afbeelding 2 van 3 Coby DVD-R11000 I/O Ports Replacement: stap 2, afbeelding 3 van 3
    • Position the DVD player so that the back is facing you
    • Grab underneath the sides of the DVD player and lift the front of it upwards.
    • Carefully pull the top of the casing off
  3. Coby DVD-R11000 I/O Ports Replacement, 3-Pin Power Cable: stap 3, afbeelding 1 van 2 Coby DVD-R11000 I/O Ports Replacement, 3-Pin Power Cable: stap 3, afbeelding 2 van 2
    • Gently pinch the 3-pin white adapter of the wire connecting the power cord to the circuit board.
    • Remove the wire from the circuit board.
  4. Coby DVD-R11000 I/O Ports Replacement, Circuit Boards: stap 4, afbeelding 1 van 2 Coby DVD-R11000 I/O Ports Replacement, Circuit Boards: stap 4, afbeelding 2 van 2
    • Position the DVD player so that the side with golden circuit board, where the power cord was plugged into, is closest to you.
    • Remove the black wire with the 6-pin white adapter, which is adjacent to the other three pin adapter wires on the golden circuit board.
  5. Coby DVD-R11000 I/O Ports Replacement: stap 5, afbeelding 1 van 3 Coby DVD-R11000 I/O Ports Replacement: stap 5, afbeelding 2 van 3 Coby DVD-R11000 I/O Ports Replacement: stap 5, afbeelding 3 van 3
    • Position the DVD player so that the back panel is facing you.
    • Remove the three wires with the white pin adapters from the golden circuit board.
  6. Coby DVD-R11000 I/O Ports Replacement: stap 6, afbeelding 1 van 3 Coby DVD-R11000 I/O Ports Replacement: stap 6, afbeelding 2 van 3 Coby DVD-R11000 I/O Ports Replacement: stap 6, afbeelding 3 van 3
    • Remove the four half inch screws, located at each corner of the golden circuit board, using the Phillips #1 screwdriver.
    • Place the blue plastic tool opener underneath the side of the circuit board and carefully remove it from the DVD player.
  7. Coby DVD-R11000 I/O Ports Replacement: stap 7, afbeelding 1 van 3 Coby DVD-R11000 I/O Ports Replacement: stap 7, afbeelding 2 van 3 Coby DVD-R11000 I/O Ports Replacement: stap 7, afbeelding 3 van 3
    • Position the DVD player so that the front is facing you.
    • Using the tweezers and the blue plastic opening tool, disconnect the ribbon cables from the green circuit board where the I/O ports are attach to.
  8. Coby DVD-R11000 I/O Ports Replacement: stap 8, afbeelding 1 van 3 Coby DVD-R11000 I/O Ports Replacement: stap 8, afbeelding 2 van 3 Coby DVD-R11000 I/O Ports Replacement: stap 8, afbeelding 3 van 3
    • Remove the three wires with the white pin adapters from the green circuit board that you just disconnected the ribbon wires from.
  9. Coby DVD-R11000 I/O Ports Replacement: stap 9, afbeelding 1 van 3 Coby DVD-R11000 I/O Ports Replacement: stap 9, afbeelding 2 van 3 Coby DVD-R11000 I/O Ports Replacement: stap 9, afbeelding 3 van 3
    • Remove the seven 1cm screws located on the back panel of the outer casing, in between the I/O ports, with the Phillips #1 screwdriver
    • Grab the sides of the back panel and remove it from the DVD player.
  10. Coby DVD-R11000 I/O Ports Replacement: stap 10, afbeelding 1 van 2 Coby DVD-R11000 I/O Ports Replacement: stap 10, afbeelding 2 van 2
    • Remove the two 1cm screws that are circled in red.
  11. Coby DVD-R11000 I/O Ports Replacement, I/O Ports: stap 11, afbeelding 1 van 1
    • De-solder the electrical components contained in the red rectangles from the green circuit board, which is the second one you removed.
    • Each red rectangle contains the electrical components for a specific group of I/O ports
Conclusie
Andrew
501 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 1-6, Shastany Fall 2014 Lid van UMass Dartmouth, Team 1-6, Shastany Fall 2014
UMASSD-SHASTANY-F14S1G6
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 5
Altijd: 178
