Ga door naar hoofdinhoud
Cobra SPX 5300 Display Screen Replacement
Wat je nodig hebt
  1. Cobra SPX 5300 Display Screen Replacement, Windshield Bracket Mount: stap 1, afbeelding 1 van 2 Cobra SPX 5300 Display Screen Replacement, Windshield Bracket Mount: stap 1, afbeelding 2 van 2
    • Remove the four 9.5 mm Phillips #0 screws from the back of the device.
  2. Cobra SPX 5300 Display Screen Replacement: stap 2, afbeelding 1 van 2 Cobra SPX 5300 Display Screen Replacement: stap 2, afbeelding 2 van 2
    • Pull the black plastic back case off of the device.
  3. Cobra SPX 5300 Display Screen Replacement: stap 3, afbeelding 1 van 1
    • Lift up the motherboard and lay it flat next to the device.
    • Be careful not to sever the wires. The buttonboard is connected to the motherboard by the wires.
  4. Cobra SPX 5300 Display Screen Replacement: stap 4, afbeelding 1 van 1
    • Remove the windshield bracket mount.
  5. Cobra SPX 5300 Display Screen Replacement, Buttonboard: stap 5, afbeelding 1 van 1
    • Remove the four 4.8 mm Phillips #00 screws from the buttonboard.
  6. Cobra SPX 5300 Display Screen Replacement: stap 6, afbeelding 1 van 1
    • Lift buttonboard to expose silver button plate.
  7. Cobra SPX 5300 Display Screen Replacement, Buttons: stap 7, afbeelding 1 van 1
    • Remove the silver button plate by gripping one of the corners and pulling up.
  8. Cobra SPX 5300 Display Screen Replacement, Display Screen: stap 8, afbeelding 1 van 2 Cobra SPX 5300 Display Screen Replacement, Display Screen: stap 8, afbeelding 2 van 2
    • Lift the front black plastic display screen.
Conclusie
Fanny Auad
286 Reputatie
2 handleidingen geschreven
Één opmerking
Hi,
Cobra SPX 7800 BT - Radar Detector
Does anyone know where could I purchase or look for a replacement screen for a Cobra SPX 7800 Bt detector, mine came with several cracks on the bottom right hand corner. It works, beeps ok, no color screen display and therefore unable to change settings.
Thanks
Ancient warrior - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 10
Altijd: 1,470
