Ga door naar hoofdinhoud
Clothing Ribbon Button Replacement
Wat je nodig hebt
  1. Clothing Ribbon Button Replacement, Ribbon Button: stap 1, afbeelding 1 van 2 Clothing Ribbon Button Replacement, Ribbon Button: stap 1, afbeelding 2 van 2
    • Examine the garment where your ribbon button came off. There should be a little pocket where the ribbon came out.
    • Stitch rip the seam around the little pocket until it is large enough to easily slide the ribbon in.
  2. Clothing Ribbon Button Replacement: stap 2, afbeelding 1 van 2 Clothing Ribbon Button Replacement: stap 2, afbeelding 2 van 2
    • Tuck one end of the ribbon into the pocket, inserting the ribbon past the missing seam.
    • If you are are using a ribbon that has an obvious front and back, insert the ribbon so that the back is facing out.
  3. Clothing Ribbon Button Replacement: stap 3, afbeelding 1 van 3 Clothing Ribbon Button Replacement: stap 3, afbeelding 2 van 3 Clothing Ribbon Button Replacement: stap 3, afbeelding 3 van 3
    • Holding the ribbon in place, slide the garment into the sewing machine, aligning the presser foot with the place you want the button to sit.
    • Do not sew the pocket with the ribbon end in it closed.
    • Sew the ribbon in place.
  4. Clothing Ribbon Button Replacement: stap 4, afbeelding 1 van 3 Clothing Ribbon Button Replacement: stap 4, afbeelding 2 van 3 Clothing Ribbon Button Replacement: stap 4, afbeelding 3 van 3
    • Backstitch to hold the stitches in place.
    • Lift the presser foot and remove the garment from the sewing machine.
    • Clip any threads.
  5. Clothing Ribbon Button Replacement: stap 5, afbeelding 1 van 3 Clothing Ribbon Button Replacement: stap 5, afbeelding 2 van 3 Clothing Ribbon Button Replacement: stap 5, afbeelding 3 van 3
    • Thread the ribbon through the button coming up from behind, over the spoke in the middle, and back down through the second hole.
  6. Clothing Ribbon Button Replacement: stap 6, afbeelding 1 van 3 Clothing Ribbon Button Replacement: stap 6, afbeelding 2 van 3 Clothing Ribbon Button Replacement: stap 6, afbeelding 3 van 3
    • Pull the ribbon taught.
    • The button should be facing with the backside out.
    • Fold the button and ribbon back over, so that the other side of the button is facing out.
    • Leave just enough ribbon to tuck into the little pocket. Clip all excess ribbon.
  7. Clothing Ribbon Button Replacement: stap 7, afbeelding 1 van 2 Clothing Ribbon Button Replacement: stap 7, afbeelding 2 van 2
    • Fold the free end of the ribbon, tucking it into the little pocket, in the same manner as the first.
    • Overlap the two ends of the ribbon so that they sit directly on top of one another.
    • Sew directly over the seam, closing the little pocket.
    • This seam should catch both ends of the ribbon between the two layers of the pocket.
  8. Clothing Ribbon Button Replacement: stap 8, afbeelding 1 van 3 Clothing Ribbon Button Replacement: stap 8, afbeelding 2 van 3 Clothing Ribbon Button Replacement: stap 8, afbeelding 3 van 3
    • Backstitch to hold the seam in place.
    • Remove the garment from the sewing machine.
  9. Clothing Ribbon Button Replacement: stap 9, afbeelding 1 van 2 Clothing Ribbon Button Replacement: stap 9, afbeelding 2 van 2
    • Clip any threads.
    • Admire your handiwork.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Brittany McCrigler
88.898 Reputatie
131 handleidingen geschreven
iFixit Lid van iFixit
Staff
136 Leden
16.563 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 25
Altijd: 2,788
