Inleiding
This guide will provide the process of heating elements of clothe iron. The heating elements of a clothe iron can stop working as a result of breaking or burning out in the process of ironing clothes. When a heating element is not working, the iron won't heat up. Unfortunately, one cannot repair most of these elements but there is usually the option of replacing them.
Wat je nodig hebt
Plug in the iron box and electric cord and bottom surface if the iron heats up or not.
To reassemble your device, follow these instructions in reverse order
4 andere personen hebben deze handleiding voltooid.
2 opmerkingen
The backwards "RU" on the old thermostat means it is a UL tested device ('recognized'). You should replace it with a UL tested device.
