Ga door naar hoofdinhoud
ClickN Kids Tablet Touch Screen Display Replacement
Wat je nodig hebt
  1. ClickN Kids Tablet Touch Screen Display Replacement, Touch Screen Display: stap 1, afbeelding 1 van 1
    • Start on the side with the camera. The screen side is black, the back side is colored
    • Insert a plastic opening tool into the space between the screen and the back side.
  2. ClickN Kids Tablet Touch Screen Display Replacement: stap 2, afbeelding 1 van 1
    • Press the plastic opening tool in until you hear a “click” and that part of the tablet opens.
    • Press and slide the plastic opening tool around all sides of the tablet until all sides pop off.
  3. ClickN Kids Tablet Touch Screen Display Replacement: stap 3, afbeelding 1 van 1
    • Lift the detached screen from the camera side until you can see the inside of the tablet.
    • Potential for device damage. Don't open too fast, or you might damage the ribbon cables.
  4. ClickN Kids Tablet Touch Screen Display Replacement: stap 4, afbeelding 1 van 2 ClickN Kids Tablet Touch Screen Display Replacement: stap 4, afbeelding 2 van 2
    • Potential for device damage. Be careful not to damage any wires or ribbon cables during this step.
    • There are two ribbon cables to remove during this step. Each is connected to a base on the motherboard.
    • There is a black tab behind the long ribbon cable. Lift up the black tab.
    • For the ribbon cable in the back, pull the black tabs on the side out.
    • Detach the ribbon cables connecting the screen to the motherboard.
    • Remove any tape that is holding down the ribbon cables. Set it aside.
    • Once the ribbon cables are freed, separate the top and bottom sides.
  5. ClickN Kids Tablet Touch Screen Display Replacement: stap 5, afbeelding 1 van 2 ClickN Kids Tablet Touch Screen Display Replacement: stap 5, afbeelding 2 van 2
    • Remove the yellow tape on the right side. Easiest side to get.
    • Remove the black and yellow tape stuck together on the left and bottom sides of the screen.
  6. ClickN Kids Tablet Touch Screen Display Replacement: stap 6, afbeelding 1 van 1
    • Potential for device damage. Make sure the screen is facedown and level to prevent or reduce damage to the display.
    • Potential for device damage. There is an adhesive on the top edge of the display’s face. Be careful not to damage the display.
    • Flex the sides of the tablet until the clips holding the display to the screen case pop loose.
  7. ClickN Kids Tablet Touch Screen Display Replacement: stap 7, afbeelding 1 van 2 ClickN Kids Tablet Touch Screen Display Replacement: stap 7, afbeelding 2 van 2
    • Be careful not to damage the display or screen case.
    • Pull the display from the top side to detach it from the screen case.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Kevin Finney
553 Reputatie
4 handleidingen geschreven
Baylor, Team 4-4, Williams Spring 2015 Lid van Baylor, Team 4-4, Williams Spring 2015
BU-WILLIAMS-S15S4G4
3 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 15
Altijd: 7,914
