Ga door naar hoofdinhoud
Clearing Paper Jam From Inside Fuser
Wat je nodig hebt
  1. Clearing Paper Jam From Inside Fuser, Unclip front top band: stap 1, afbeelding 1 van 2 Clearing Paper Jam From Inside Fuser, Unclip front top band: stap 1, afbeelding 2 van 2
    • Insert prying tool behind each end of the plastic strip. Pry outwards to unclip and pull the ends forwards away from the printer.
    • Note - Unclipping the right-hand end requires opening the toner cover for access.
  2. Clearing Paper Jam From Inside Fuser, Unclip front top band: stap 2, afbeelding 1 van 2 Clearing Paper Jam From Inside Fuser, Unclip front top band: stap 2, afbeelding 2 van 2
    • Insert prying tool between the front band and top cover of the printer, and pry forwards to release the clips holding the top edge in place.
  3. Clearing Paper Jam From Inside Fuser, Remove front top band: stap 3, afbeelding 1 van 1
    • Tilt the top of the front band away from the printer and lift away to remove.
  4. Clearing Paper Jam From Inside Fuser, Remove left-side top band: stap 4, afbeelding 1 van 3 Clearing Paper Jam From Inside Fuser, Remove left-side top band: stap 4, afbeelding 2 van 3 Clearing Paper Jam From Inside Fuser, Remove left-side top band: stap 4, afbeelding 3 van 3
    • Unclip the back end of the plastic trim by prying away from the printer back panel.
    • Pull the trim piece towards the back of the printer.
    • Tilt the top edge away from the printer and lift away to remove.
  5. Clearing Paper Jam From Inside Fuser, Remove control panel module: stap 5, afbeelding 1 van 3 Clearing Paper Jam From Inside Fuser, Remove control panel module: stap 5, afbeelding 2 van 3 Clearing Paper Jam From Inside Fuser, Remove control panel module: stap 5, afbeelding 3 van 3
    • Pry up front edge of the control panel module to unclip.
    • Lift up front edge and pull module forwards slightly to unhook rear edge.
    • Pull out cable connector to unplug the display/ control panel module.
  6. Clearing Paper Jam From Inside Fuser, Remove front cover: stap 6, afbeelding 1 van 1
    • Remove the front lower flap by carefully bending in the middle and pulling out the locating pins one end at a time.
  7. Clearing Paper Jam From Inside Fuser, Remove front cover: stap 7, afbeelding 1 van 1
    • Remove both 7mm phillips screws securing the front cover in place.
  8. Clearing Paper Jam From Inside Fuser, Remove front cover: stap 8, afbeelding 1 van 3 Clearing Paper Jam From Inside Fuser, Remove front cover: stap 8, afbeelding 2 van 3 Clearing Paper Jam From Inside Fuser, Remove front cover: stap 8, afbeelding 3 van 3
    • Unclip the three clips along each end of the front cover by prying outwards and forwards with a prying tool as shown.
  9. Clearing Paper Jam From Inside Fuser, Remove front cover: stap 9, afbeelding 1 van 1
    • Slide out the bottom edge away from the printer and pull the front cover down away from the top edge to remove.
  10. Clearing Paper Jam From Inside Fuser, Remove top cover: stap 10, afbeelding 1 van 2 Clearing Paper Jam From Inside Fuser, Remove top cover: stap 10, afbeelding 2 van 2
    • Undo both the 5mm M3 phillips screws holding the top cover brackets to the chassis.
  11. Clearing Paper Jam From Inside Fuser, Remove top cover: stap 11, afbeelding 1 van 2 Clearing Paper Jam From Inside Fuser, Remove top cover: stap 11, afbeelding 2 van 2
    • Pull the top cover brackets forwards off the metal frame and lift up to loosen the front edge of the top cover.
  12. Clearing Paper Jam From Inside Fuser, Remove top cover: stap 12, afbeelding 1 van 1
    • Pry the top cover clip off the locating peg at the back of the printer, and lift up the top cover corner.
  13. Clearing Paper Jam From Inside Fuser, Remove top cover: stap 13, afbeelding 1 van 1
    • Pry apart the back edge of the top cover and the back cover of the printer to unclip the top cover.
  14. Clearing Paper Jam From Inside Fuser, Remove top cover: stap 14, afbeelding 1 van 1
    • Lift up the top cover from the control panel corner, pulling towards the back right-hand corner.
    • Note - The top cover should unclip from the back corner with the corner/side piece still attached.
  15. Clearing Paper Jam From Inside Fuser, Loosen fuser cover plate: stap 15, afbeelding 1 van 1
    • Before working on the fuser module, ensure it has cooled down since last use as the fuser reaches high temperatures while printing.
    • Unscrew the two 10mm phillips screws holding the top cover to the fuser module.
  16. Clearing Paper Jam From Inside Fuser, Loosen fuser cover plate: stap 16, afbeelding 1 van 2 Clearing Paper Jam From Inside Fuser, Loosen fuser cover plate: stap 16, afbeelding 2 van 2
    • Unhook the right-hand end (as viewed facing the back of the printer) by pulling forwards and out from beneath the retainer.
    • Unhook the left end of the cover by pushing the right end towards the front of the printer until the left retaining hook is free of the retainer.
  17. Clearing Paper Jam From Inside Fuser, Lift up cover plate: stap 17, afbeelding 1 van 3 Clearing Paper Jam From Inside Fuser, Lift up cover plate: stap 17, afbeelding 2 van 3 Clearing Paper Jam From Inside Fuser, Lift up cover plate: stap 17, afbeelding 3 van 3
    • While lifting up the cover plate, take care to avoid bending the retaining spring out of shape
    • The fuser top cover can be lifted up as shown to access inside the fuser unit to remove any remaining pieces of jammed paper.
    • If any paper is caught between the rollers, lift up the two blue tabs under the back cover to release the pressure off the rollers and pull the paper out.
Conclusie
Jac
2.728 Reputatie
21 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 31
Altijd: 454
