Ga door naar hoofdinhoud
Cleaning/Degreasing Heat Sink
Wat je nodig hebt
  1. Cleaning/Degreasing Heat Sink, Cleaning Debris from Flywheel Screen: stap 1, afbeelding 1 van 3 Cleaning/Degreasing Heat Sink, Cleaning Debris from Flywheel Screen: stap 1, afbeelding 2 van 3 Cleaning/Degreasing Heat Sink, Cleaning Debris from Flywheel Screen: stap 1, afbeelding 3 van 3
    • Ensure the engine is off and cooled down before starting this guide.
    • Using a 5/16" socket or wrench, remove the three bolts holding the plastic cover on to the engine.
    • Lift away the plastic cover. Note that the starter is attached to the cover and will come off with it.
  2. Cleaning/Degreasing Heat Sink: stap 2, afbeelding 1 van 2 Cleaning/Degreasing Heat Sink: stap 2, afbeelding 2 van 2
    • Using compressed air or a rag, clean debris from the flywheel.
  3. Cleaning/Degreasing Heat Sink, Cleaning/Degreasing Heat Sink: stap 3, afbeelding 1 van 2 Cleaning/Degreasing Heat Sink, Cleaning/Degreasing Heat Sink: stap 3, afbeelding 2 van 2
    • Using compressed air and a rag, clean the heat sink.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Aaron Correya
239 Reputatie
2 handleidingen geschreven
Cal Poly, Team S25-G15, Maness Spring 2018 Lid van Cal Poly, Team S25-G15, Maness Spring 2018
CPSU-MANESS-S18S25G15
4 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 378
