Ga door naar hoofdinhoud
Cleaning the Fan Blades
Wat je nodig hebt
  1. Cleaning the Fan Blades, PCB (Printed Circuit Board): stap 1, afbeelding 1 van 1
    • Use the Phillips #2 screwdriver to remove the four 6 mm screws by unscrewing counterclockwise.
  2. Cleaning the Fan Blades: stap 2, afbeelding 1 van 1
    • Pull the front and back cover apart.
    • Be careful not to pull the front cover off completely. It holds the wires.
  3. Cleaning the Fan Blades: stap 3, afbeelding 1 van 1
    • Remove the Phillips 6 mm screw that holds the circuit board to the outer shell of the fan.
    • Shock warning: Make sure the fan is unplugged before removing the circuit board.
  4. Cleaning the Fan Blades: stap 4, afbeelding 1 van 1
    • Remove the top cover containing the circuit board and the wires by pulling it away from the outer shell of the fan.
  5. Cleaning the Fan Blades: stap 5, afbeelding 1 van 2 Cleaning the Fan Blades: stap 5, afbeelding 2 van 2
    • Remove the screws from the four corners of the circuit board.
    • Remove the circuit board from the top cover.
    • Do not touch the other side of the circuit board to avoid damaging the circuit elements.
  6. Cleaning the Fan Blades, Fan Blades: stap 6, afbeelding 1 van 1
    • Follow steps 1-4 to remove the front, back, and top covers of the fan to reach the fan blades.
    • Use a cloth to clean off dust clogged in between the fan blades.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Vivian Fong
97 Reputatie
1 Handleiding geschreven
Cal Poly, Team 15-46, Forte Fall 2012 Lid van Cal Poly, Team 15-46, Forte Fall 2012
CPSU-FORTE-F12S15G46
5 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 89
Altijd: 10,213
