Ga door naar hoofdinhoud
Cleaning Debris from Flywheel Screen
Wat je nodig hebt
  1. Cleaning Debris from Flywheel Screen, Cleaning Debris from Flywheel Screen: stap 1, afbeelding 1 van 3 Cleaning Debris from Flywheel Screen, Cleaning Debris from Flywheel Screen: stap 1, afbeelding 2 van 3 Cleaning Debris from Flywheel Screen, Cleaning Debris from Flywheel Screen: stap 1, afbeelding 3 van 3
    • Ensure the engine is off and cooled down before starting this guide.
    • Using a 5/16" socket or wrench, remove the three bolts holding the plastic cover on to the engine.
    • Lift away the plastic cover. Note that the starter is attached to the cover and will come off with it.
  2. Cleaning Debris from Flywheel Screen: stap 2, afbeelding 1 van 2 Cleaning Debris from Flywheel Screen: stap 2, afbeelding 2 van 2
    • Using compressed air or a rag, clean debris from the flywheel.
Conclusie
Ethan Narad
529 Reputatie
3 handleidingen geschreven
Cal Poly, Team S25-G15, Maness Spring 2018 Lid van Cal Poly, Team S25-G15, Maness Spring 2018
CPSU-MANESS-S18S25G15
4 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 1,001
