Inleiding
The coffee spout is a part that is rarely cleaned and is not cleaned efficiently by the cleaning program.
This guide will show you how to easily disassemble and manually clean it.
These instructions may also help with other Siemens/Bosch models — they have a very similar design.
Wat je nodig hebt
Now slide the spudger/screwdriver between the plastic cap and the cover and gently pry in the direction of the coffee machine. This pushes the cover over the barb.
Grab the cover by the sides and pull it up. This is often very difficult, so pull it hard but not excessively.
Work through the steps in reverse order to reassemble your device.
Één andere persoon heeft deze handleiding voltooid.
Met dank aan deze vertalers:
100%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
