Inleiding
Follow this guide to replace the upper V-Belt on a 2018 Classen Sod Cutter model HSC18AHD.
Wat je nodig hebt
Use a 1/2 inch socket to remove the first two bolts from the belt shield.
Use a 1/2 inch socket to remove the third bolt from the belt shield.
Use your fingers to roll the belt. If you cannot twist the belt more than a quarter turn, the belt is sufficiently tensioned. If the belt is too loose, set the idler pulley lower to tension the belt more.
