Inleiding
This guide shows how to remove and replace the control switch on the Clarke EZ-8 floor sander.
Wat je nodig hebt
Stap 1 Disconnect all power cables
Voorzichtig: stap 1 komt van een handleiding die in bewerking is.
Slide the collar on the control link arm up until the two halves of the arm detach from one another.
Use a socket wrench with a deep 9/16" socket to remove the retaining nut and star washer from the control switch toggle.
Use a Phillips #2 screwdriver to remove the six screws on the control housing—three on either side.
Lift the control housing up and swing it open so the wiring panel inside is accessible.
Use a #2 Phillips head screwdriver to remove the following three screws from the wiring panel:
Two 10-32 x 3/8" screws
One 8-32 x 3/8" screw
Remove the ring and fork terminals from the screws.
Pull and gently wiggle the control switch to remove it from its mounting hole in the control housing.
9 andere personen hebben deze handleiding voltooid.
2 opmerkingen
Well Done, steps are clear and EZ 8 to follow!
Thank you excellent instruction
