Ga door naar hoofdinhoud
Inleiding
Although the Ecodrive watches made by Citizen contain a rechargeable battery, after a long period of usage the battery is no longer able to hold a charge. When that occurs, it would be less expensive to replace the battery instead of buying a new watch. This guide demonstrates how to properly perform a battery replacement on a Citizen Ecodrive watch.
Onderdelen
Geen onderdelen opgegeven.
  1. Remove pin from watch band link to obtain easier access to the back of the watch.
    • Remove pin from watch band link to obtain easier access to the back of the watch.
  2. Using the adjustable wrench, unscrew the back face of the watch. Using the adjustable wrench, unscrew the back face of the watch.
    • Using the adjustable wrench, unscrew the back face of the watch.
  3. PC Laptop batterijen
    Een snelle fix voor een grote boost.
    Nu winkelen
    Nu winkelen
  4. Using the sim removal tool, carefully pry the capacitor from its current location.
    • Using the sim removal tool, carefully pry the capacitor from its current location.
  5. Replace the capacitor with the new lithium capacitor. Make sure the positive side is facing upward.
    • Replace the capacitor with the new lithium capacitor.
    • Make sure the positive side is facing upward.
    • When reinserting capacitor, make sure the brass connector is inserted into the inlet of the battery slot.
  6. Pull the knob out for thirty seconds to place the watch in its "all reset" mode. Pull the knob out for thirty seconds to place the watch in its "all reset" mode.
    • Pull the knob out for thirty seconds to place the watch in its "all reset" mode.
Conclusie
To reassemble your device, follow the steps in reverse order.
17 andere personen hebben deze handleiding voltooid.
Billy Tat
569 Reputatie
1 Handleiding geschreven
How about citizen c605? How to open for replace capacitor?cheers
Citizen alex - Antwoord
Before doing any repairs it might be a good idea to do these:
1. Place the watch to bright sunshine for one full day the dial facing straight to the sun.
2. After the sun treatment pull the knop fully out and keep it that way for 30 seconds (or more).
3. Press the knop back in and wait for 10 seconds.
4. If the watch now works normally, you saved the battery price and your fixing work…
5. If not, you unfortunately have to do as instructed here.
Good luck!
Seppo Nikkilä - Antwoord
Does the Capacitor of an Eco-drive watch has a tendency to leak?
citizen ph - Antwoord
No Generally speaking electrolitic capacitors dry out from old age but these just lose their ability to hold a charge…. no leaking
Jeff Kohlmann -
Where can I get an adjustable wrench like the one in the picture?
Timothy Zorn - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 108
Afgelopen 7 Dagen: 670
Afgelopen 30 Dagen: 2,958
Altijd: 77,554
