Inleiding
If you need to access the internal components of the Cisco Meraki MC74-HW or replace a broken back housing cover or stand, use this guide. This process requires a plastic spudger, bit driver, 150 mm flex extension, and H2.0 bit. The following steps present no threat or potential damage to your device.
Wat je nodig hebt
Extend the stand as far away as possible from the device.
Remove all four 3 mm Hex 2 screws from the stand.
Bijna klaar!
Conclusie
