Ga door naar hoofdinhoud
Cisco Meraki MC74-HW Back Housing and Device Stand Replacement
Wat je nodig hebt
  1. Cisco Meraki MC74-HW Back Housing and Device Stand Replacement, Back Housing and Device Stand: stap 1, afbeelding 1 van 3 Cisco Meraki MC74-HW Back Housing and Device Stand Replacement, Back Housing and Device Stand: stap 1, afbeelding 2 van 3 Cisco Meraki MC74-HW Back Housing and Device Stand Replacement, Back Housing and Device Stand: stap 1, afbeelding 3 van 3
    • Extend the stand as far away as possible from the device.
    • Remove all four 3 mm Hex 2 screws from the stand.
    • A bit with a flexible extension may be needed to remove these screws.
  2. Cisco Meraki MC74-HW Back Housing and Device Stand Replacement: stap 2, afbeelding 1 van 2 Cisco Meraki MC74-HW Back Housing and Device Stand Replacement: stap 2, afbeelding 2 van 2
    • Lift the stand off the device.
  3. Cisco Meraki MC74-HW Back Housing and Device Stand Replacement: stap 3, afbeelding 1 van 3 Cisco Meraki MC74-HW Back Housing and Device Stand Replacement: stap 3, afbeelding 2 van 3 Cisco Meraki MC74-HW Back Housing and Device Stand Replacement: stap 3, afbeelding 3 van 3
    • Insert a plastic spudger between the back housing cover and the sensor cover piece.
    • Work your way slowly around the edges of the device until all the clips have been unclipped.
    • Do not insert any tool recklessly into the device or you might damage wires and connections.
  4. Cisco Meraki MC74-HW Back Housing and Device Stand Replacement: stap 4, afbeelding 1 van 2 Cisco Meraki MC74-HW Back Housing and Device Stand Replacement: stap 4, afbeelding 2 van 2
    • Separate the back housing cover from the device completely.
Conclusie
Anthony Kairouz
253 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 1-5, Simcock Fall 2021 Lid van UMass Dartmouth, Team 1-5, Simcock Fall 2021
UMASSD-SIMCOCK-F21S1G5
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 6
Altijd: 191
