Ga door naar hoofdinhoud
Cisco 878 Integrated Services Router Top Cover Disassembly
Wat je nodig hebt
  1. Cisco 878 Integrated Services Router Top Cover Disassembly, Remove the two screws on back side: stap 1, afbeelding 1 van 3 Cisco 878 Integrated Services Router Top Cover Disassembly, Remove the two screws on back side: stap 1, afbeelding 2 van 3 Cisco 878 Integrated Services Router Top Cover Disassembly, Remove the two screws on back side: stap 1, afbeelding 3 van 3
    • Only trained and qualified personnel should be allowed to install, replace, or service this equipment!
    • During this procedure, wear grounding wrist straps to avoid ESD damage to the card. Do not directly touch the backplane with your hand or any metal tool, or you could shock yourself!
    • Make sure that the power switch is turned to standby and that the power supply cable is disconnected. Disconnect all cables from the router back panel.
    • Use the Phillips #1 Screwdriver to remove the two screws on back side of the device.
  2. Cisco 878 Integrated Services Router Top Cover Disassembly, Remove top cover: stap 2, afbeelding 1 van 3 Cisco 878 Integrated Services Router Top Cover Disassembly, Remove top cover: stap 2, afbeelding 2 van 3 Cisco 878 Integrated Services Router Top Cover Disassembly, Remove top cover: stap 2, afbeelding 3 van 3
    • 1. Gently push the top cover of the router away from you.
    • 2. Lift it up top cover from the bottom of the router.
    • 3. Remove top cover from the device.
    • Place the router bottom on an antistatic mat.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jiri Altman
1.563 Reputatie
9 handleidingen geschreven
4k20 Repair Team Lid van 4k20 Repair Team
Community
2 Leden
17 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 408
