Ga door naar hoofdinhoud
Onderdelen
Geen onderdelen opgegeven.
  1. Only trained and qualified personnel should be allowed to install, replace, or service this equipment! During this procedure, wear grounding wrist straps to avoid ESD damage to the card. Do not directly touch the backplane with your hand or any metal tool, or you could shock yourself! Make sure that the power switch is turned to standby and that the power supply cable is disconnected. Disconnect all cables from the router back panel.
    • Only trained and qualified personnel should be allowed to install, replace, or service this equipment!
    • During this procedure, wear grounding wrist straps to avoid ESD damage to the card. Do not directly touch the backplane with your hand or any metal tool, or you could shock yourself!
    • Make sure that the power switch is turned to standby and that the power supply cable is disconnected. Disconnect all cables from the router back panel.
    • Use the Phillips #1 Screwdriver to remove the two screws on back side of the device.
  2. 1. Gently push the top cover of the router away from you. 2. Lift it up top cover from the bottom of the router. 3. Remove top cover from the device.
    • 1. Gently push the top cover of the router away from you.
    • 2. Lift it up top cover from the bottom of the router.
    • 3. Remove top cover from the device.
    • Place the router bottom on an antistatic mat.
  3. Use the Phillips #1 Screwdriver to remove the three screws on front side of the device. Use the Phillips #1 Screwdriver to remove the three screws on front side of the device.
    • Use the Phillips #1 Screwdriver to remove the three screws on front side of the device.
  4. 1. Gently lift up inner metal shield from the bottom of the router. 2. Remove inner metal shield from the device (see the anchors on the picture). Be careful and do not distort the plates!
    • 1. Gently lift up inner metal shield from the bottom of the router.
    • 2. Remove inner metal shield from the device (see the anchors on the picture).
    • Be careful and do not distort the plates!
  5. 1. Place your fingers on the levers at the two sides of the slot, and push open. 2. Firmly pull the release lever away from the module until the module pops up. 3. You can then remove the module from the module slot.
    • 1. Place your fingers on the levers at the two sides of the slot, and push open.
    • 2. Firmly pull the release lever away from the module until the module pops up.
    • 3. You can then remove the module from the module slot.
  6. 1. Use the Phillips #1 Screwdriver to remove the black screw.
    • 1. Use the Phillips #1 Screwdriver to remove the black screw.
    • 2. Use the Phillips #1 Screwdriver to remove the silver screw as shown on picture.
    • You should remove just only one silver screw - the second one is holding just cooling plate.
  7. Gently pull the module up to disconnect two connectors underneath. Be careful and don't damage 4-pin connector (marked RED). Be careful and don't damage 4-pin connector (marked RED).
    • Gently pull the module up to disconnect two connectors underneath.
    • Be careful and don't damage 4-pin connector (marked RED).
  8. Use the Phillips #1 Screwdriver to remove the two screws holding the motherboard.
    • Use the Phillips #1 Screwdriver to remove the two screws holding the motherboard.
    • When putting screws back, don't use force - threads are made of plastic!
  9. 1. Gently lift up the board to release plastic locks. 2. Gently pull the board away from backside panel (to release metal shielding locks around connectors). 3. Remove board from the case.
    • 1. Gently lift up the board to release plastic locks.
    • 2. Gently pull the board away from backside panel (to release metal shielding locks around connectors).
    • 3. Remove board from the case.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jiri Altman
1.479 Reputatie
8 handleidingen geschreven
4k20 Repair Team Lid van 4k20 Repair Team
Community
2 Leden
0 Opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 11
Altijd: 317
