Inleiding
Remove the inner metal shield to access internal components of Cisco 878 device.
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Use the Phillips #1 Screwdriver to remove the two screws on back side of the device.
1. Gently push the top cover of the router away from you.
2. Lift it up top cover from the bottom of the router.
3. Remove top cover from the device.
Use the Phillips #1 Screwdriver to remove the three screws on front side of the device.
1. Gently lift up inner metal shield from the bottom of the router.
2. Remove inner metal shield from the device (see the anchors on the picture).
Één andere persoon heeft deze handleiding voltooid.
