Ga door naar hoofdinhoud
Circuit Board Housing Removal
Wat je nodig hebt
  1. Circuit Board Housing Removal, Battery: stap 1, afbeelding 1 van 2 Circuit Board Housing Removal, Battery: stap 1, afbeelding 2 van 2
    • Locate the horizontal grip located on the back cover of the phone.
    • Slide the back cover down and off of the phone.
  2. Circuit Board Housing Removal: stap 2, afbeelding 1 van 2 Circuit Board Housing Removal: stap 2, afbeelding 2 van 2
    • Insert a plastic opening tool into the battery release point located above the battery.
    • Pull outwards in order to release the battery.
  3. Circuit Board Housing Removal, Circuit Board Housing: stap 3, afbeelding 1 van 3 Circuit Board Housing Removal, Circuit Board Housing: stap 3, afbeelding 2 van 3 Circuit Board Housing Removal, Circuit Board Housing: stap 3, afbeelding 3 van 3
    • Locate the 5 screws holding the body of the phone together.
    • The top screw will have a plastic cover, remove it using tweezers.
    • Using a Philips head screwdriver, twist counterclockwise to remove the screws.
    • Take special care with the screw located at the top of the phone. It is smaller and more likely to be damaged or improperly attached.
  4. Circuit Board Housing Removal: stap 4, afbeelding 1 van 2 Circuit Board Housing Removal: stap 4, afbeelding 2 van 2
    • Lift the back cover starting at the bottom of the phone.
  5. Circuit Board Housing Removal: stap 5, afbeelding 1 van 2 Circuit Board Housing Removal: stap 5, afbeelding 2 van 2
    • Remove the back cover completely from the phone.
Conclusie
Jonathan Flowers
607 Reputatie
6 handleidingen geschreven
Clemson, Team 14-7, Benson Fall 2013 Lid van Clemson, Team 14-7, Benson Fall 2013
CLEM-BENSON-F13S14G7
3 Leden
16 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 597
