Ga door naar hoofdinhoud
Cirago M9030 Motherboard Replacement
Wat je nodig hebt
  1. Cirago M9030 Motherboard Replacement, Cover: stap 1, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the top of the cover.
  2. Cirago M9030 Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Similar to the last step, flip the cover over and use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the bottom of the cover.
    • Remove the warranty sticker across the bottom.
  3. Cirago M9030 Motherboard Replacement: stap 3, afbeelding 1 van 2 Cirago M9030 Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Gently take the cover apart using your hands separating the top and bottom.
    • The outer shell is expected to easily come apart.
  4. Cirago M9030 Motherboard Replacement, Hard Drive: stap 4, afbeelding 1 van 1
    • Make sure that the screen of the device is facing down.
  5. Cirago M9030 Motherboard Replacement: stap 5, afbeelding 1 van 3 Cirago M9030 Motherboard Replacement: stap 5, afbeelding 2 van 3 Cirago M9030 Motherboard Replacement: stap 5, afbeelding 3 van 3
    • Using the plastic opening tool, wedge the tool underneath the bottom left edge of the hard drive.
    • Raise the bottom edge of the hard drive 15 degrees up from the device.
  6. Cirago M9030 Motherboard Replacement: stap 6, afbeelding 1 van 3 Cirago M9030 Motherboard Replacement: stap 6, afbeelding 2 van 3 Cirago M9030 Motherboard Replacement: stap 6, afbeelding 3 van 3
    • Place fingers on the IDE connectors gently picking up and sliding the hard drive out from the IDE module.
  7. Cirago M9030 Motherboard Replacement, IDE Connector: stap 7, afbeelding 1 van 2 Cirago M9030 Motherboard Replacement, IDE Connector: stap 7, afbeelding 2 van 2
    • Using the Phillips #00 screwdriver, unscrew the two 1.5mm long screws holding the IDE connector to the motherboard located at the top.
  8. Cirago M9030 Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Using the Phillips #00 screwdriver, unscrew the three 1.5mm long screws on the metal bracket.
  9. Cirago M9030 Motherboard Replacement: stap 9, afbeelding 1 van 2 Cirago M9030 Motherboard Replacement: stap 9, afbeelding 2 van 2
    • Using the plastic opening tool, completely lift the metal bracket off of the motherboard.
    • Using the plastic opening tool, completely lift the rubber insulator off of the motherboard.
  10. Cirago M9030 Motherboard Replacement: stap 10, afbeelding 1 van 1
    • Using the plastic opening tool, completely lift the ribbon off of the motherboard.
  11. Cirago M9030 Motherboard Replacement: stap 11, afbeelding 1 van 2 Cirago M9030 Motherboard Replacement: stap 11, afbeelding 2 van 2
    • Completely remove the IDE connector from the device.
    • The audio jack is attached to the IDE connector. Pull at a 45 degree angle from the audio jack.
  12. Cirago M9030 Motherboard Replacement, Motherboard: stap 12, afbeelding 1 van 2 Cirago M9030 Motherboard Replacement, Motherboard: stap 12, afbeelding 2 van 2
    • Using the plastic opening tool, wedge the tool underneath the top edge of the motherboard.
    • Completely remove the motherboard.
    • The motherboard should slide out easily.
Conclusie
Ryan Sutardji
171 Reputatie
7 handleidingen geschreven
Cal Poly, Team 1-4, Regan SU 2012 Lid van Cal Poly, Team 1-4, Regan SU 2012
CPSU-REGAN-SU12S1G4
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 15
Altijd: 1,018
