Ga door naar hoofdinhoud
Cingular 8125 Speakers Replacement
Wat je nodig hebt
    • Hold the phone with the back (camera side) facing you.
    • Press on the battery cover until it slides off.
  1. Cingular 8125 Speakers Replacement: stap 2, afbeelding 1 van 1
    • Lift up the black tab that sticks out on the battery's side until the battery is pulled out.
    • Using the iFixit Opening Tool, pull on the phone's camera cover until it pops off.
  2. Cingular 8125 Speakers Replacement: stap 3, afbeelding 1 van 1
    • Remove the four black Torx head screws in each corner.
  3. Cingular 8125 Speakers Replacement: stap 4, afbeelding 1 van 1
    • Pull on the back cover of the phone with the iFixit opening tool until the green motherboard is revealed.
  4. Cingular 8125 Speakers Replacement: stap 5, afbeelding 1 van 1
    • Remove the black plastic piece from the motherboard by gently pulling it off.
    • Align the white squares on the motherboard and the speakers.
    • You'll know they are lined up correctly when the speaker's wires face the motherboard's center.
    • Press down on the white squares until they snap together.
  5. Cingular 8125 Speakers Replacement: stap 6, afbeelding 1 van 1
    • Place the back cover of the phone over the motherboard.
    • Check to be sure the speaker's black piece is against the holes in the back cover.
    • Screw the four Torx head screws with the 64 Bit Driver Handle to connect the back cover to the motherboard.
    • Press the camera cover down on the back cover until it snaps into place.
    • Line up the copper terminal on the battery with the terminal on the phone, then press the battery back into place.
    • Make sure the black tab sticks out.
    • Slide the battery cover over the camera cover until it snaps back into place.
Conclusie
Laura Kimberly Simonds
301 Reputatie
2 handleidingen geschreven
University of Maine, Team 1-1, Diaz Fall 2012 Lid van University of Maine, Team 1-1, Diaz Fall 2012
UMAINE-DIAZ-F12S1G1
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 9
Altijd: 366
