Ga door naar hoofdinhoud
Chumby One Motherboard Replacement
Wat je nodig hebt
  1. Chumby One Motherboard Replacement, Chassis: stap 1, afbeelding 1 van 1
    • Remove 4 self-adhesive plastic dots covering the screw holes.
  2. Chumby One Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Remove the four 2mm screws with a Phillips screwdriver.
  3. Chumby One Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Remove the back and bottom cover.
  4. Chumby One Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Disconnect the battery connector from the motherboard with a plastic opening tool.
  5. Chumby One Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Disconnect the microphone connector from the motherboard with a plastic opening tool.
  6. Chumby One Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Remove the display ribbon cable from its socket with a plastic opening tool.
  7. Chumby One Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Remove the volume knob from the side of the Chumby One with a plastic opening tool.
  8. Chumby One Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Remove the four 6mm screws using a PH000 bit on the inner chassis.
  9. Chumby One Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Remove the inner components from the outer shell.
  10. Chumby One Motherboard Replacement, Motherboard: stap 10, afbeelding 1 van 1
    • Remove the speaker connector using a plastic spudger.
  11. Chumby One Motherboard Replacement: stap 11, afbeelding 1 van 1
    • Remove the Chumby button connector using a plastic spudger.
  12. Chumby One Motherboard Replacement: stap 12, afbeelding 1 van 1
    • Remove three 6mm screws using a PH000 bit.
  13. Chumby One Motherboard Replacement: stap 13, afbeelding 1 van 1
    • Remove the motherboard by pulling straight away from the housing.
    • Removing the motherboard there are 2 pins and socket connectors that may cause injury.
Conclusie
Jordan Houchins
401 Reputatie
4 handleidingen geschreven
IUPUI, Team S3-G3, Baechle Spring 2017 Lid van IUPUI, Team S3-G3, Baechle Spring 2017
IUPUI-BAECHLE-S17S3G3
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 269
