Ga door naar hoofdinhoud
Chumby One LCD Screen Replacement
Wat je nodig hebt
  1. Chumby One LCD Screen Replacement, Chassis: stap 1, afbeelding 1 van 1
    • Remove 4 self-adhesive plastic dots covering the screw holes.
  2. Chumby One LCD Screen Replacement: stap 2, afbeelding 1 van 1
    • Remove the four 2mm screws with a Phillips screwdriver.
  3. Chumby One LCD Screen Replacement: stap 3, afbeelding 1 van 1
    • Remove the back and bottom cover.
  4. Chumby One LCD Screen Replacement: stap 4, afbeelding 1 van 1
    • Disconnect the battery connector from the motherboard with a plastic opening tool.
  5. Chumby One LCD Screen Replacement: stap 5, afbeelding 1 van 1
    • Disconnect the microphone connector from the motherboard with a plastic opening tool.
  6. Chumby One LCD Screen Replacement: stap 6, afbeelding 1 van 1
    • Remove the display ribbon cable from its socket with a plastic opening tool.
  7. Chumby One LCD Screen Replacement: stap 7, afbeelding 1 van 1
    • Remove the volume knob from the side of the Chumby One with a plastic opening tool.
  8. Chumby One LCD Screen Replacement: stap 8, afbeelding 1 van 1
    • Remove the four 6mm screws using a PH000 bit on the inner chassis.
  9. Chumby One LCD Screen Replacement: stap 9, afbeelding 1 van 1
    • Remove the inner components from the outer shell.
  10. Chumby One LCD Screen Replacement, LCD Screen: stap 10, afbeelding 1 van 1
    • Remove the four 5.5mm screws with a Phillips PH000 screwdriver bit.
  11. Chumby One LCD Screen Replacement: stap 11, afbeelding 1 van 1
    • Remove the metal shield from the front case using a plastic opening tool.
  12. Chumby One LCD Screen Replacement: stap 12, afbeelding 1 van 1
    • Remove the LCD screen from the outer case using a plastic opening tool.
Conclusie
Jordan Houchins
401 Reputatie
4 handleidingen geschreven
IUPUI, Team S3-G3, Baechle Spring 2017 Lid van IUPUI, Team S3-G3, Baechle Spring 2017
IUPUI-BAECHLE-S17S3G3
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 9
Altijd: 220
