Inleiding
This guide will help you to remove the back panel of the Chromo Noria in order to replace it or begin repairing your device! Taking off the back panel is essential to fixing anything inside the Noria.
Wat je nodig hebt
Insert your Plastic Opening Tool into the crease between the front panel and back panel.
Slide the Opening Tool around the entire device. As you progress, you should see the device open.
Één andere persoon heeft deze handleiding voltooid.
