Ga door naar hoofdinhoud
Chromo Inc. T2 Internal Speaker Replacement
Wat je nodig hebt
  1. Chromo Inc. T2 Internal Speaker Replacement, Removing the Casing: stap 1, afbeelding 1 van 3 Chromo Inc. T2 Internal Speaker Replacement, Removing the Casing: stap 1, afbeelding 2 van 3 Chromo Inc. T2 Internal Speaker Replacement, Removing the Casing: stap 1, afbeelding 3 van 3
    • Using your Plastic Opening Tool, place it in between the screen and the case. Slowly move it around the casing while prying in a downward motion to undo the hinges holding the two together and separate the two parts.
  2. Chromo Inc. T2 Internal Speaker Replacement, Turn it around: stap 2, afbeelding 1 van 1
    • After separating the case and screen, turn your screen face down so you can see the internal parts!
  3. Chromo Inc. T2 Internal Speaker Replacement, Removing the Tape: stap 3, afbeelding 1 van 3 Chromo Inc. T2 Internal Speaker Replacement, Removing the Tape: stap 3, afbeelding 2 van 3 Chromo Inc. T2 Internal Speaker Replacement, Removing the Tape: stap 3, afbeelding 3 van 3
    • Remove two strips of tape: One holding down the wires and the other holding down the internal speaker.
  4. Chromo Inc. T2 Internal Speaker Replacement, Desoldering the Wires and Removing the Speaker: stap 4, afbeelding 1 van 3 Chromo Inc. T2 Internal Speaker Replacement, Desoldering the Wires and Removing the Speaker: stap 4, afbeelding 2 van 3 Chromo Inc. T2 Internal Speaker Replacement, Desoldering the Wires and Removing the Speaker: stap 4, afbeelding 3 van 3
    • Using a Soldering Iron, desolder both speaker wires. Once both wires are desoldered, your Internal Speaker is now ready for replacement!
    • Soldering Iron gets very hot, take care to not touch anywhere on the soldering iron except for the handle!
Conclusie
Ismael DeLuna
637 Reputatie
5 handleidingen geschreven
USF Tampa, Team 15-1, Watkins Winter 2015 Lid van USF Tampa, Team 15-1, Watkins Winter 2015
USFT-WATKINS-W15S15G1
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 208
