Ga door naar hoofdinhoud
Onderdelen
Geen onderdelen opgegeven.
  1. Place your Plastic Opening Tool between the screen and the case. Slowly move it around the casing while prying in a downward motion to undo the hinges holding the two together and separate the two parts. Place your Plastic Opening Tool between the screen and the case. Slowly move it around the casing while prying in a downward motion to undo the hinges holding the two together and separate the two parts. Place your Plastic Opening Tool between the screen and the case. Slowly move it around the casing while prying in a downward motion to undo the hinges holding the two together and separate the two parts.
    • Place your Plastic Opening Tool between the screen and the case. Slowly move it around the casing while prying in a downward motion to undo the hinges holding the two together and separate the two parts.
  2. After separating the case and screen, turn your screen face down so you can see the internal parts!
    • After separating the case and screen, turn your screen face down so you can see the internal parts!
  3. Android Fix Kits
    Slechts één reparatie scheidt jou van een nieuw scherm of een nieuwe batterij.
    Nu winkelen
    Android Fix Kits
    Nu winkelen
  4. Using the Spudger, going between the battery and screen, pry the battery off from the tablet. Note: This will require a little extra force due to the tape holding down the battery! Note: This will require a little extra force due to the tape holding down the battery!
    • Using the Spudger, going between the battery and screen, pry the battery off from the tablet.
    • Note: This will require a little extra force due to the tape holding down the battery!
  5. Using a Soldering Iron, desolder both Battery wires.
    • Using a Soldering Iron, desolder both Battery wires.
    • Soldering Iron gets very hot, take care to not touch anywhere on the soldering iron except for the handle!
  6. Your battery is now ready to be replaced!
    • Your battery is now ready to be replaced!
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Ismael DeLuna
601 Reputatie
5 handleidingen geschreven
USF Tampa, Team 15-1, Watkins Winter 2015 Lid van USF Tampa, Team 15-1, Watkins Winter 2015
USFT-WATKINS-W15S15G1
4 Leden
6 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 1,283
