Ga door naar hoofdinhoud
Chromecast Power Button Replacement
Wat je nodig hebt
  1. Chromecast Power Button Replacement, Case: stap 1, afbeelding 1 van 1
    • Place the Google Chromecast face down (with text not showing) on a flat surface.
    • Insert a flat tool just above the micro-USB port to detach the top part of the case from the bottom.
  2. Chromecast Power Button Replacement: stap 2, afbeelding 1 van 1
    • Continue prying the top of the case from the bottom toward the HDMI port until the top casing is completely removed.
  3. Chromecast Power Button Replacement: stap 3, afbeelding 1 van 1
    • Remove the circuit board, lifting from the HDMI port.
    • The power button may become dislodged.
  4. Chromecast Power Button Replacement: stap 4, afbeelding 1 van 1
    • Pry the plastic clamp from the heatsink.
    • Do not pry too hard to avoid breaking the clamp.
  5. Chromecast Power Button Replacement: stap 5, afbeelding 1 van 2 Chromecast Power Button Replacement: stap 5, afbeelding 2 van 2
    • Insert a plastic opening tool under the heatsink, and pry the heatsink up and out of the case.
    • The adhesive's strength may vary, and force should be applied gently until it becomes dislodged to avoid breaking the device.
  6. Chromecast Power Button Replacement, Power Button: stap 6, afbeelding 1 van 1
    • Press the plastic button from the outside of the port, pushing it inward if it is stuck.
Conclusie
Cameron Heiges
680 Reputatie
3 handleidingen geschreven
IUPUI, Team S5-G6, Baechle Spring 2018 Lid van IUPUI, Team S5-G6, Baechle Spring 2018
IUPUI-BAECHLE-S18S5G6
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 972
