Ga door naar hoofdinhoud
Chromecast Metal Shielding Replacement
Wat je nodig hebt
  1. Chromecast Metal Shielding Replacement, Case: stap 1, afbeelding 1 van 1
    • Place the Google Chromecast face down (with text not showing) on a flat surface.
    • Insert a flat tool just above the micro-USB port to detach the top part of the case from the bottom.
  2. Chromecast Metal Shielding Replacement: stap 2, afbeelding 1 van 1
    • Continue prying the top of the case from the bottom toward the HDMI port until the top casing is completely removed.
  3. Chromecast Metal Shielding Replacement: stap 3, afbeelding 1 van 1
    • Remove the circuit board, lifting from the HDMI port.
    • The power button may become dislodged.
  4. Chromecast Metal Shielding Replacement: stap 4, afbeelding 1 van 1
    • Pry the plastic clamp from the heatsink.
    • Do not pry too hard to avoid breaking the clamp.
  5. Chromecast Metal Shielding Replacement: stap 5, afbeelding 1 van 2 Chromecast Metal Shielding Replacement: stap 5, afbeelding 2 van 2
    • Insert a plastic opening tool under the heatsink, and pry the heatsink up and out of the case.
    • The adhesive's strength may vary, and force should be applied gently until it becomes dislodged to avoid breaking the device.
  6. Chromecast Metal Shielding Replacement, Metal Shielding: stap 6, afbeelding 1 van 1
    • Pry the metal extensions from the HDMI port.
  7. Chromecast Metal Shielding Replacement: stap 7, afbeelding 1 van 1
    • Insert the plastic opening tool into the corner next to the metal extensions, prying upward.
  8. Chromecast Metal Shielding Replacement: stap 8, afbeelding 1 van 1
    • Pry the metal piece around the metal, extruding it from the internal components.
  9. Chromecast Metal Shielding Replacement: stap 9, afbeelding 1 van 1
    • Completely remove the top metal casing to expose the internal components.
  10. Chromecast Metal Shielding Replacement: stap 10, afbeelding 1 van 1
    • Pry metal extensions from the HDMI port on the posterior side of the device.
  11. Chromecast Metal Shielding Replacement: stap 11, afbeelding 1 van 1
    • Insert the plastic opening tool under the corner to pry off the metal casing from the internal components.
  12. Chromecast Metal Shielding Replacement: stap 12, afbeelding 1 van 1
    • Continue prying around the device, removing the metal piece from the internal components.
  13. Chromecast Metal Shielding Replacement: stap 13, afbeelding 1 van 1
    • Completely remove the bottom metal piece.
Conclusie
Cameron Heiges
680 Reputatie
3 handleidingen geschreven
IUPUI, Team S5-G6, Baechle Spring 2018 Lid van IUPUI, Team S5-G6, Baechle Spring 2018
IUPUI-BAECHLE-S18S5G6
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 1,624
