Inleiding
This guide will walk users through replacing the cooling fan of the Chromebook x360 14-da0011dx. Fans accumulate debris and dust over time, causing malfunction or reduced function. If possible, clean fan debris and retry connection before replacing the fan altogether.
Wat je nodig hebt
Flip the device over with the hinge facing away from you.
On the back of the device, remove the two rubber strips on the top and the bottom of the device using a spudger.
Één andere persoon heeft deze handleiding voltooid.
