Ga door naar hoofdinhoud
Chromebook Pixel (2013) Battery Replacement
Wat je nodig hebt
  1. Chromebook Pixel (2013) Battery Replacement, Remove the rubber pads: stap 1, afbeelding 1 van 2 Chromebook Pixel (2013) Battery Replacement, Remove the rubber pads: stap 1, afbeelding 2 van 2
    • Flip your Chromebook Pixel over onto its back
    • Using a flat edge screwdriver, gently pull up to remove the rubber pads from the laptop to reveal the screws
  2. Chromebook Pixel (2013) Battery Replacement, Removing the bottom panel: stap 2, afbeelding 1 van 3 Chromebook Pixel (2013) Battery Replacement, Removing the bottom panel: stap 2, afbeelding 2 van 3 Chromebook Pixel (2013) Battery Replacement, Removing the bottom panel: stap 2, afbeelding 3 van 3
    • Using a small Philips screwdriver, remove the four screws under the pads
    • Using a spudger (or another flat but slightly blunt object), gently pry the laptop open
    • You may find it helpful to start with a smaller (skinnier) head and work your way up to a larger size
  3. Chromebook Pixel (2013) Battery Replacement, Pop it open: stap 3, afbeelding 1 van 2 Chromebook Pixel (2013) Battery Replacement, Pop it open: stap 3, afbeelding 2 van 2
    • Gently pull up from the front of the laptop and open it up like a clamshell
  4. Chromebook Pixel (2013) Battery Replacement, Remove the write protect screw (IF APPLICABLE): stap 4, afbeelding 1 van 2 Chromebook Pixel (2013) Battery Replacement, Remove the write protect screw (IF APPLICABLE): stap 4, afbeelding 2 van 2
    • Locate the write protect screw
    • Remove it and you can begin flashing your BIOS!
  5. Chromebook Pixel (2013) Battery Replacement, Remove the bottom cover: stap 5, afbeelding 1 van 1
    • You should have your Chromebook Pixel flipped over and the bottom cover removed at this point
  6. Chromebook Pixel (2013) Battery Replacement, Release the battery: stap 6, afbeelding 1 van 1
    • Remove the screws holding the battery in place.
  7. Chromebook Pixel (2013) Battery Replacement, Unplug the battery: stap 7, afbeelding 1 van 2 Chromebook Pixel (2013) Battery Replacement, Unplug the battery: stap 7, afbeelding 2 van 2
    • Using a splunger or your finger and a gentle pull, unplug the battery from the Pixel logic board
    • Pull the battery toward you to remove it
  8. Chromebook Pixel (2013) Battery Replacement, Examine the new battery: stap 8, afbeelding 1 van 1
    • Make sure that the wattage and voltage matches the values of the old battery
  9. Chromebook Pixel (2013) Battery Replacement, Install the new battery: stap 9, afbeelding 1 van 2 Chromebook Pixel (2013) Battery Replacement, Install the new battery: stap 9, afbeelding 2 van 2
    • Follow these steps in reverse and turn on the Pixel.
    • If the old battery was failing, will have to reset the system time when you log back into Chrome OS or your installed Operating System
Conclusie
8 andere personen hebben deze handleiding voltooid.
Kevin Fessler
1.770 Reputatie
4 handleidingen geschreven
2 opmerkingen
You can now find these batteries on Amazon too- just search for the same part number GP-S22-000000-0100
riansanderson - Antwoord
Hello could someone help
Where would i get a replacement battery from ? having trouble locating one .
Thanks in advance nick
Nick Harrisson - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 34
Altijd: 7,077
