Ga door naar hoofdinhoud
Chevy 305 Engine Connecting Rod Bearing Replacement
Wat je nodig hebt
  1. Chevy 305 Engine Connecting Rod Bearing Replacement, Connecting Rod Bearing: stap 1, afbeelding 1 van 2 Chevy 305 Engine Connecting Rod Bearing Replacement, Connecting Rod Bearing: stap 1, afbeelding 2 van 2
    • Remove the 18 bolts holding the oil pan in place using the 3⁄8 and 1⁄2 sockets, 6 inch extension and 3⁄8 ratchet.
    • Fourteen 3/8 bolts around the perimeter and four 1/2 bolts on each corner
    • Lift the oil pan up and forward so the oil pump pick up will clear the baffle.
    • Do not remove the oil pan gasket yet.
  2. Chevy 305 Engine Connecting Rod Bearing Replacement: stap 2, afbeelding 1 van 1
    • Remove the two 5/8 nuts on the connecting rod end cap using the 5/8 socket
    • Gently tap the side of the cap with a rubber mallet if needed to break free.
  3. Chevy 305 Engine Connecting Rod Bearing Replacement: stap 3, afbeelding 1 van 1
    • Remove and replace connecting rod bearing
    • Gently tap the end cap against the engine block or use a thin flathead screwdriver to remove it from the end cap.
    • Gently move the piston and rod down into the cylinder to replace the rod end bearing.
    • DO NOT PUSH THE PISTON OUT OF THE CYLINDER.
  4. Chevy 305 Engine Connecting Rod Bearing Replacement: stap 4, afbeelding 1 van 1
    • Liberally apply assembly lubricant/oil to the new bearing surfaces and crankshaft journal.
Conclusie
To reassemble your device, follow these instructions in reverse order. Torque the connecting rod cap nuts to 65ft.-lbs. Torque the oil pan bolts to 12ft.-lbs.
4 andere personen hebben deze handleiding voltooid.
Joey Barton
364 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 40
Altijd: 2,287
