Ga door naar hoofdinhoud
Cherry Stream Desktop - Low Profile Keycap - Repair
  1. Cherry Stream Desktop - Low Profile Keycap - Repair, Place components on a flat surface: stap 1, afbeelding 1 van 2 Cherry Stream Desktop - Low Profile Keycap - Repair, Place components on a flat surface: stap 1, afbeelding 2 van 2
    • Image 1: Put the 3 components on a flat surface. The keycap (black component)
    • Image 2: the 2-component bracket
  2. Cherry Stream Desktop - Low Profile Keycap - Repair, Click bracket on keycap: stap 2, afbeelding 1 van 2 Cherry Stream Desktop - Low Profile Keycap - Repair, Click bracket on keycap: stap 2, afbeelding 2 van 2
    • image 1: Click the inserts of the smaller bracket onto the keycap
    • image 2: once it's clicked, the bracket should stay in place if you shake the keycap
  3. Cherry Stream Desktop - Low Profile Keycap - Repair, Join the small with the larger bracket: stap 3, afbeelding 1 van 2 Cherry Stream Desktop - Low Profile Keycap - Repair, Join the small with the larger bracket: stap 3, afbeelding 2 van 2
    • Image 1: Insert the pin of the small bracket onto the larger one.
    • Note: There are two small pins. Ideally, you should insert both. One after the other. But if one breaks, the keycap will still work.
    • Image 2: Just place the larger bracket on the keycap. There is no click
  4. Cherry Stream Desktop - Low Profile Keycap - Repair, The final touch: stap 4, afbeelding 1 van 3 Cherry Stream Desktop - Low Profile Keycap - Repair, The final touch: stap 4, afbeelding 2 van 3 Cherry Stream Desktop - Low Profile Keycap - Repair, The final touch: stap 4, afbeelding 3 van 3
    • Image 1: you need to orient the keycap so that it can click to the tiny metal bar
    • Note: This is just a reference
    • Image 2: Once oriented, place the keycap on top of the space for the keycap on the keyboard, while holding the white bracket.
    • Next, simply press the keycap down
    • Image 3: Congratulations! Your keyboard should be working again. :D
Conclusie
Beatriz Pozo Arcos
927 Reputatie
4 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 34
Altijd: 680
