Ga door naar hoofdinhoud
Chefman RJ-38-V2-35 Fryer Basket Replacement
Wat je nodig hebt
  1. Chefman RJ-38-V2-35 Fryer Basket Replacement, Fryer Basket: stap 1, afbeelding 1 van 1
    • Make sure the air fryer is unplugged and the basket is cool enough to handle.
    • Remove the basket from the air fryer.
  2. Chefman RJ-38-V2-35 Fryer Basket Replacement: stap 2, afbeelding 1 van 1
    • Place the fryer basket on a flat surface.
    • Using the Phillips #1 screwdriver, remove four 5mm screws on the inside of the fryer basket (left two screws shown).
  3. Chefman RJ-38-V2-35 Fryer Basket Replacement: stap 3, afbeelding 1 van 1
    • Separate the handle from the basket.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Benn Rutledge
127 Reputatie
1 Handleiding geschreven
UW Tacoma, Team S1-G4, Rose Fall 2018 Lid van UW Tacoma, Team S1-G4, Rose Fall 2018
UWT-ROSE-F18S1G4
4 Leden
3 handleidingen geschreven
4 opmerkingen
I need the plate inside the basket. The coating is coming off, Is it safe to use?
Eileen Morrison - Antwoord
Where can I buy only the basket or just the plate? I need replacement but don’t seem to find the parts…
Eszter Stranszky - Antwoord
I need the plate inside the basket. Coating is coming off.
Sandy Mentzer - Antwoord
Where can I buy replacement rubber feet for the fryer basket plate? Mine came off and went down the disposal!! Are they required for proper heating and frying??
Betty Johnson - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 47
Altijd: 3,501
