Inleiding
This guide shows the disassembly of a Chef's Counter Rice Cooker RC-3. This page can be helpful in understanding the makeup of your device and potentially identifying a problem. To ensure your safety, please unplug the device before continuing with the disassembly. This is an easy disassembly but an extra set of hands is helpful.
Wat je nodig hebt
Unplug the rice cooker.
Remove the bowl and lid from the device and place the device upside down on a flat surface.
Now that the device is disassembled you can get a better understanding on how it works.
The rice cooker receives constant power when plugged in. A mechanical lever is used to switch between warm and cook settings. The settings are indicated by white LED lights with orange and red plastic coverings on the outer control panel.
A DF184S Thermal Cutoff Fuse is in place to protect the device by disconnecting the circuit in the event of a heating element malfunction.
