Ga door naar hoofdinhoud
Changing SSD disk why! N131WU
Wat je nodig hebt
  1. Changing SSD disk why! N131WU, Remove the Screws: stap 1, afbeelding 1 van 1
    • Remove the case screws (red) and the keyboard screws (green).
    • Be sure not to lose these screws. You will need them to reassemble your laptop.
  2. Changing SSD disk why! N131WU, Remove the Keyboard: stap 2, afbeelding 1 van 3 Changing SSD disk why! N131WU, Remove the Keyboard: stap 2, afbeelding 2 van 3 Changing SSD disk why! N131WU, Remove the Keyboard: stap 2, afbeelding 3 van 3
    • Using the hole provided under the case (see picture), push the keyboard out using a thin screwdriver or some other solid object.
    • Hold onto the keyboard as you push the keyboard so as not to damage the two cables still attached.
  3. Changing SSD disk why! N131WU, Remove Keyboard Connections: stap 3, afbeelding 1 van 3 Changing SSD disk why! N131WU, Remove Keyboard Connections: stap 3, afbeelding 2 van 3 Changing SSD disk why! N131WU, Remove Keyboard Connections: stap 3, afbeelding 3 van 3
    • (Blue Cable) Push up on the thin black portion on the connector and gently pull out the blue ribbon cable until it comes out.
    • (Orange Cable) Remove the orange cable by sliding the gray part of the connector towards the screen, then gently pull on the ribbon cable.
  4. Changing SSD disk why! N131WU, Remove the upper screws: stap 4, afbeelding 1 van 2 Changing SSD disk why! N131WU, Remove the upper screws: stap 4, afbeelding 2 van 2
    • Unscrew the three screws that were under the keyboard. Be sure to hold onto these.
    • After these are removed, you can now remove the lower part of the case from the rest of the computer.
  5. Changing SSD disk why! N131WU, Remove the SSD: stap 5, afbeelding 1 van 3 Changing SSD disk why! N131WU, Remove the SSD: stap 5, afbeelding 2 van 3 Changing SSD disk why! N131WU, Remove the SSD: stap 5, afbeelding 3 van 3
    • Remove the screw holding in the ssd.
    • Carefully remove the SSD from the connector.
Conclusie
Met dank aan deze vertalers:
fr en
100%
Deze vertalers helpen ons de wereld te repareren! Doe je mee?
Begin met vertalen ›
Felice Suglia
33.538 Reputatie
283 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 679
