Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Place the meter face down, and the back panel and screws can be seen.
Unscrew the two 9mm screws on the back panel using a #0 Phillips screwdriver.
Remove the back panel of the device by lifting upward.
Remove the battery from the meter before continuing.
Remove the four 7mm Phillips screws holding the circuit board in place.
Gently lift the circuit board away from the device casing.
The dial is located in the central part of the device.
Carefully remove dial from device by lifting upward.
Clean existing dial or replace if necessary.
Één andere persoon heeft deze handleiding voltooid.
