Ga door naar hoofdinhoud
Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement
Wat je nodig hebt
  1. Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement, Position Device: stap 1, afbeelding 1 van 1
    • Place the meter face down, and the back panel and screws can be seen.
  2. Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement, Remove Back Panel Screws: stap 2, afbeelding 1 van 2 Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement, Remove Back Panel Screws: stap 2, afbeelding 2 van 2
    • Unscrew the two 9mm screws on the back panel using a #0 Phillips screwdriver.
  3. Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement, Remove Back Panel: stap 3, afbeelding 1 van 1
    • Remove the back panel of the device by lifting upward.
    • Remove the battery from the meter before continuing.
  4. Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement, Unscrew Motherboard: stap 4, afbeelding 1 van 2 Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement, Unscrew Motherboard: stap 4, afbeelding 2 van 2
    • Remove the four 7mm Phillips screws holding the circuit board in place.
  5. Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement, Remove Motherboard: stap 5, afbeelding 1 van 1
    • Gently lift the circuit board away from the device casing.
    • Remove the battery after removing the back cover to reduce the chances of short-circuiting the circuit board.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Anna Kihm
956 Reputatie
5 handleidingen geschreven
Clemson, Team 2-4, Benson Fall 2014 Lid van Clemson, Team 2-4, Benson Fall 2014
CLEM-BENSON-F14S2G4
4 Leden
6 handleidingen geschreven
1Gids Commentaar
What is the little dial on the circuit board on the upper right that has numbers 1 through 3 on it and it can be adjusted thank you
Thomas Clawson - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 21
Altijd: 2,847
