Ga door naar hoofdinhoud
Celestron Nature DX Focus Knob Replacement
Wat je nodig hebt
  1. Celestron Nature DX Focus Knob Replacement, Skin Cover: stap 1, afbeelding 1 van 2 Celestron Nature DX Focus Knob Replacement, Skin Cover: stap 1, afbeelding 2 van 2
    • Using a plastic opening tool, nylon spudger or metal spudger, pry into seam of the skin cover at the center of the device. Lightly lift the tool which should cause the skin cover to rise.
  2. Celestron Nature DX Focus Knob Replacement: stap 2, afbeelding 1 van 2 Celestron Nature DX Focus Knob Replacement: stap 2, afbeelding 2 van 2
    • Start peeling the skin away from the center. Apply force as there is an adhesive substance that is binding the skin to the device. Continue peeling until skin cover slides off completely.
  3. Celestron Nature DX Focus Knob Replacement: stap 3, afbeelding 1 van 1
    • Repeat steps 1 and 2 for the other side.
  4. Celestron Nature DX Focus Knob Replacement, Focus Knob: stap 4, afbeelding 1 van 1
    • Remove the top cover of the focus knob as shown. Simply twisting and pulling the cover will slide it off.
  5. Celestron Nature DX Focus Knob Replacement: stap 5, afbeelding 1 van 1
    • Use a magnetic pickup tool or magnetic screwdriver head to remove the guard. The guard should come right off without much resistance.
  6. Celestron Nature DX Focus Knob Replacement: stap 6, afbeelding 1 van 1
    • Unscrew the focus knob. It should come off without much resistance or pressure.
    • Parts revealed will be heavily lubricated. Consider wearing gloves.
Conclusie
Bryce Colangelo
525 Reputatie
5 handleidingen geschreven
USF Tampa, Team S6-G6, Lacy Spring 2017 Lid van USF Tampa, Team S6-G6, Lacy Spring 2017
USFT-LACY-S17S6G6
4 Leden
10 handleidingen geschreven
Één opmerking
Hello.
I have the same model with a little bit to hard working focus knob.
Is it possible to adjust it in order to make it working smoothly?
Tkanks.
Zenon Zuza - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 16
Altijd: 861
