Inleiding
Use this guide to replace the power supply board of the device. This includes detaching the power cables connected to the logic board, which requires desoldering.
Wat je nodig hebt
Lay the device on its back, and rotate so the base is facing away from you.
Unplug the cable connecting the display to the power supply using the flat end of the spudger to pry the connector away from the circuit board.
Één andere persoon heeft deze handleiding voltooid.
