Ga door naar hoofdinhoud
Ceiva LF2003 Exterior Frame and Matting Replacement
  1. Ceiva LF2003 Exterior Frame and Matting Replacement, Exterior Frame and Matting: stap 1, afbeelding 1 van 1
    • Lay the device on its back, and rotate so the base is facing away from you.
  2. Ceiva LF2003 Exterior Frame and Matting Replacement: stap 2, afbeelding 1 van 1
    • Grip the frame with your fingers under the edge of the frame, and thumbs pushing down on the front of the device.
  3. Ceiva LF2003 Exterior Frame and Matting Replacement: stap 3, afbeelding 1 van 1
    • Lift up the frame with your fingers and push down the rest of the device with your thumbs.
  4. Ceiva LF2003 Exterior Frame and Matting Replacement: stap 4, afbeelding 1 van 1
    • Remove the frame and matte from the device.
Conclusie
Casey Glasgow
510 Reputatie
5 handleidingen geschreven
Cal Poly, Team 9-25, Maness Winter 2014 Lid van Cal Poly, Team 9-25, Maness Winter 2014
CPSU-MANESS-W14S9G25
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 79
