Inleiding
Replacing the display on this device is not very difficult. A couple sets of screws and wires are all that need removing, but don't rush or you might rip a cable.
Wat je nodig hebt
Lay the device on its back, and rotate so the base is facing away from you.
Unplug the cable connecting the display to the power supply using the flat end of the spudger to pry the connector away from the circuit board.
Één andere persoon heeft deze handleiding voltooid.
