Ga door naar hoofdinhoud
Caterpillar B15 SIM Card Replacement
Wat je nodig hebt
  1. Caterpillar B15 SIM Card Replacement, SIM Card: stap 1, afbeelding 1 van 1
    • Place the phone screen-side down and place thumb on the yellow and black switch. Slide the switch to the right to unlock the back covering for removal.
  2. Caterpillar B15 SIM Card Replacement: stap 2, afbeelding 1 van 2 Caterpillar B15 SIM Card Replacement: stap 2, afbeelding 2 van 2
    • Remove the back covering by gently lifting upwards from the bottom of the back covering. The back will snap off and the battery is exposed.
  3. Caterpillar B15 SIM Card Replacement: stap 3, afbeelding 1 van 2 Caterpillar B15 SIM Card Replacement: stap 3, afbeelding 2 van 2
    • Place index finger at the top edge of the battery and gently lift upwards. The battery will slide cleanly out of the phone. The SIM card slot lies under the battery.
  4. Caterpillar B15 SIM Card Replacement: stap 4, afbeelding 1 van 1
    • The old SIM card is removed and replaced with the new one. The phone can be reassembled by following these steps in reverse order.
Conclusie
Geoffrey Mosdell
1.119 Reputatie
5 handleidingen geschreven
USF Tampa, Team 4-7, Brown Fall 2014 Lid van USF Tampa, Team 4-7, Brown Fall 2014
USFT-BROWN-F14S4G7
4 Leden
10 handleidingen geschreven
Één opmerking
Mi celular dice SIM no detectada que puedo hacer
Jerson Vargas - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 34
Altijd: 15,323
